Jester Posted May 15, 2016 Share #1 Posted May 15, 2016 Installing Barron's Lowering kit. Put in the new links. working on the caliper re-locator. I can only get axle 1/2 way out. tried removing all weight and lowering it down off the jack. no difference. Had to tap it with hammer and ratchet extension to get this far. Making me nervous. Any thoughts on what I am doing wrong? Also if anyone ahs pictures of the finished product for the locators I would appreciate it. Not exactly sure what it should look like in the end. Link to comment Share on other sites More sharing options...
k9cottage Posted May 15, 2016 Share #2 Posted May 15, 2016 sometimes when removing the axel the spacer collar and washer will jam on the swing arm [right hand side] a light tap on the swing arm will free it. Link to comment Share on other sites More sharing options...
Jester Posted May 15, 2016 Author Share #3 Posted May 15, 2016 thanks I will try that after dinner Link to comment Share on other sites More sharing options...
bongobobny Posted May 15, 2016 Share #4 Posted May 15, 2016 Yup! Loosen the pinch bolt a whole bunch more then pry the gap open more... Link to comment Share on other sites More sharing options...
Jester Posted May 15, 2016 Author Share #5 Posted May 15, 2016 I pulled the bolt on the caliper mount. Slid right out. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
bongobobny Posted May 15, 2016 Share #6 Posted May 15, 2016 OK!! I can see where that could help too!! Link to comment Share on other sites More sharing options...
