ledraveur Posted May 13, 2016 Posted May 13, 2016 excuse my English Hello I took my bike for the summer and when I gave it everything functioned now when I click on audio does not start nothing happens over the fuse is good music you have a small idea of the problem thank you for your answer I'm from quebec canada
bongobobny Posted May 13, 2016 Posted May 13, 2016 excuse my French Did you disconnect your battery over the winter? If so then the audio system has turned itself off. If the battery went dead over the winter then the same thing happened. The display will be blank if this is the case. Consult your owner's manual for how to turn it back on. You simply press the "Audio" button to turn on. The Audio button is the one on the left of the three buttons below the display. If you press and hold the same button for a few seconds it turns the system off. The fuse for the radio is in the lower front fairing on the right side. It is a 10 amp fuse that is on the side of the fuse block. This information is also in the owner's manual. Here is a link to the owner's manual, hopefully you can translate it into French... http://labs.trunkful.com/vrmanuals/LIT-11626-16-15_18.pdf
ledraveur Posted May 13, 2016 Author Posted May 13, 2016 Hello I already press the audio button but nothing happens and the fuse is ok thanqs-
Freebird Posted May 13, 2016 Posted May 13, 2016 I may be wrong, but if I remember correctly, there are actually two fuses. One behind the left side cover and the other in the right lower? If they are both good, then the next thing I would do is split the fairing and clean the large black connectors.
