Wizard765 Posted April 10, 2008 Posted April 10, 2008 Hi Folks: Does anyone know if the antenna mount from an 86 or newer will fit or bolt up to an 84 trunk bracket? The 86 has an S bend in it that lends nicely to having a right angle adapter in place while the 84 is just a straight pipe. Wayne
Condor Posted April 10, 2008 Posted April 10, 2008 Hi Folks: Does anyone know if the antenna mount from an 86 or newer will fit or bolt up to an 84 trunk bracket? The 86 has an S bend in it that lends nicely to having a right angle adapter in place while the 84 is just a straight pipe. Wayne Don't think so Wayne. Attached are a couple of 83,87, and 91 pics. Looks like the markII has two bolts, while the markI has a bolt and tab. Different trunk rack also....
Wizard765 Posted April 11, 2008 Author Posted April 11, 2008 Thanks for the pics Condor. I'll have to find another solution. Hmmmmm.....
