KAWoodworth Posted February 15, 2016 Posted February 15, 2016 I'm getting ready to tackle checking my valve clearance on my 2007 Royal Star Venture. I know I need 2 valve cover gaskets. The fantastic write up that VGoose posted says to remove the carbs. Do I need any new gaskets for the carbs? If I need new carb gaskets what are the part numbers on them from Parts Shark. Every winter when I put my bike up there is always a couple of drops of coolant that leaks out from the freeze plugs. Does anyone know the part number of the freeze plugs from Parts Shark and how many do I need? I would like to replace them. Thanks
Freebird Posted February 15, 2016 Posted February 15, 2016 You shouldn't need anything for the carbs. Though it would be a fantastic time to check and set the float levels while you have them off. If you do that, you MAY need new bowl gaskets but I was careful and able to reuse mine.
Guest Jamsie Posted February 15, 2016 Posted February 15, 2016 part number for plug 90338-11152-00 . you can use an old spark plug to screw into them so you can pull them out
Guest Jamsie Posted February 15, 2016 Posted February 15, 2016 edit wont let me put link to parts list https://www.shopyamaha.com/parts-catalog/parts/star-mcy#/Yamaha/ROYAL_STAR_VENTURE_-_XVZ13TFW_-_2007/CRANKCASE/XVZ13TFW_(2007_MOTORCYCLE)/CRANKCASE_(XVZ13TFW_-_2007)
KAWoodworth Posted February 16, 2016 Author Posted February 16, 2016 Thanks guys. I was planning to try and set the carb float levels while I have them off.
