stevernc Posted November 2, 2015 Posted November 2, 2015 Does anyone know if the axle, on a 2000 mm edition venture, is larger for any reason. I am trying to install a Barons lowering kit and the axle does not fit through the Barons bracket. I contact Barons and they affirmed the Kit I have is the correct one. Anyone else ever experience this problem?
eagleeye Posted November 2, 2015 Posted November 2, 2015 Find a machine shop near you and have them measure the ID with an inside mic, and then get back to barons with that number and see what they say. I have that kit on my 05 RSTD, which should be the same. Might as well take the axle along too. I suppose you could double check and see if there is a burr somewhere causing the problem. I just went out and looked at mine, and no way to do it wrong.
eusa1 Posted November 3, 2015 Posted November 3, 2015 the axle is the same on every year of royal star venture and royal star tour deluxe 1999-2013
