midnightrider1300 Posted August 30, 2015 #1 Posted August 30, 2015 2010 Venture...My steering is to loose, jack it up handle bars crash over and bounce 2 or three times, I have a wobble on start offs.... question what SIZE is the Chrome nut 28 29 or 30 ... lol I don't have one that size and an adjustable wont work ... then next question how tight should the tree be?
M61A1MECH Posted August 30, 2015 #2 Posted August 30, 2015 It is a 28 mm, but you should also tighten up the tabbed locking nuts on the bottom. see this write up, http://www.venturerider.org/forum/showthread.php?511-Tightening-the-Steering-Head
Eck Posted August 30, 2015 #3 Posted August 30, 2015 Midnightrider1300, I deleted your other (duplicate) thread to avoid confusion.
midnightrider1300 Posted August 30, 2015 Author #4 Posted August 30, 2015 Eck said: Midnightrider1300, I deleted your other (duplicate) thread to avoid confusion. thanks I don't know HOW it duplicated ....
midnightrider1300 Posted August 30, 2015 Author #5 Posted August 30, 2015 M61A1MECH said: It is a 28 mm, but you should also tighten up the tabbed locking nuts on the bottom. see this write up, http://www.venturerider.org/forum/showthread.php?511-Tightening-the-Steering-Head thanks I knew I'd have to tighten those after I loosened the big nut on top.... a 1 1/16" will fit it couldn't find a 28mm
