taz112 Posted August 14, 2015 Posted August 14, 2015 I have a 1986 Venture Royal that runs great when warmed up. The problem is it takes about 20 minutes of running under load before it stops stalling. After warmed up if I stop for more than five minutes it stalls again until run five or ten minutes under load. This is very frustrating, any one else experience this? Thanks for your input! Sent from my NX785QC using Tapatalk
Chaharly Posted August 14, 2015 Posted August 14, 2015 Have you checked your fuel filter? If it looks good then I would try pulling your pilot jets out and feeding a G or B guitar string through the orifices. I find that the E string felt too small
Flyinfool Posted August 14, 2015 Posted August 14, 2015 Start by checking the exhaust pipes when starting from cold to see if they are all warming up at the same rate. Maybe you are not running on all 4 cylinders. These bikes run amazingly well on 3 cyl (some never notice that they lost one) and still run but noticeably rough on 2 cyl.
