chag67 Posted May 24, 2015 Share #1 Posted May 24, 2015 Can someone post a link to a video or a step by step set of pictures for changing the oil on a 2nd Gen Venture? I work better if I can see the step by steps or someone shows me in a video or in person. I've also done a search on YouTube and can't seem to find anything for a Venture. Thanks. Link to comment Share on other sites More sharing options...
chag67 Posted May 24, 2015 Author Share #2 Posted May 24, 2015 And what kind of oil do you guys like the best? Link to comment Share on other sites More sharing options...
bill4you502 Posted May 24, 2015 Share #3 Posted May 24, 2015 .....Oil change is really simple. Run the engine for 10 min or so. Remove the oil filler cap (Behind your right side foot board), remove the bolt from under the oil pan and drain the oil, and, while your at it, change the oil filter (in front of the engine under the radiator). I use Yamalube oil (20W-50) and Yamalube filter. Hand tighten the new oil filter, fill with the proper amount of oil and replace the oil filler cap. Run the engine for 10 min or so then, with the bike upright, check the sight glass on the lower right side. It should be 1/2 full or better. .....Some members use different oil and filters that all seem to work O.K. The beauty of this site is all the help available....Did I miss anything guys (And girls!)? Link to comment Share on other sites More sharing options...
djh3 Posted May 24, 2015 Share #4 Posted May 24, 2015 You will need a 2x4 or suitable substitute to "level" out the bike on the side stand to check correct level of oil. Put the board under the kickstand, drain oil. Change filter. Last change I used a mobil1 M110. Purolator was popular but changed the design and now they will not work. There is a thread around about the problems with some of the filters we like to use other than the Yamaha one. Shell rotella T6 for a synthetic oil is popular if you want syn oil or the rotella t5 I think is the dino oil. Any oil that has a JSAMO rating is OK for wet clutch. The T^ is like $20 a gallon at Wally World. On the right side of the engine (forward and lower) there is a site glass. Do not fill more than half way when your all done withe service. It blow excess oil in to the air box and then it will make its way all over the top of the engine eventually. I think about 3.2 qt with a filter is what is recommended. Link to comment Share on other sites More sharing options...
chag67 Posted May 24, 2015 Author Share #5 Posted May 24, 2015 Thanks. I plan on using the motorcycle stand in the auto hobby shop on the military base down here. $3/hr to use a stall. All tools and oil disposal are free. Link to comment Share on other sites More sharing options...
