Dale124 Posted August 10, 2014 Share #1 Posted August 10, 2014 Well, after searching this site for the low down on how to remove the cassette deck and turn it into a storage space, I had no luck finding the post. I'm sure I've seen it here before. Anyway, I want to keep the aux jack available, and perhaps put an iPod in the slot when I want tunes. Has anyone done this, and if so, how did it go? Dale. Link to comment Share on other sites More sharing options...
bikerjohn Posted August 10, 2014 Share #2 Posted August 10, 2014 I pulled mine and put gauges! The Ipod will connect to a cable off the stereo unit. Once you go in you will see the cable Link to comment Share on other sites More sharing options...
Sylvester Posted August 10, 2014 Share #3 Posted August 10, 2014 I pulled mine and put gauges! The Ipod will connect to a cable off the stereo unit. Once you go in you will see the cable Same thing I did. I guess that is a "ditto". Sure miss Ponch. Is anyone else doing the gauge set up? Link to comment Share on other sites More sharing options...
BG Hawks Posted August 10, 2014 Share #4 Posted August 10, 2014 I did it and it went well. The deck will slide out with some manuvering; becareful! I ran the aux jack back into the now storage area and that's where my Ipod sits. I had to get a 2nd cassette deck and gut it because my cassette door broke. I don't believe it was because of the work that I did; it never really opened all that great to begin. Not to brag up the other site but there is directions and that's where I started. Good Luck! Feel free to PM if you have questions! Link to comment Share on other sites More sharing options...
