Donvito Posted July 28, 2014 Share #1 Posted July 28, 2014 My intercom's not working on an 87 VR. The earphones will play music but the intercom doesn't operate. Before I buy new headsets I would like to test it to make sure the headsets are the problem. I live in the Clearwater, Florida area so if anyone in the area has a pair of working headsets I would come to you to try them out. Thanks. Link to comment Share on other sites More sharing options...
Bob Myers Posted July 28, 2014 Share #2 Posted July 28, 2014 If the radio will play through the headset then your headset is OK. Does the CB work, can others hear you? What headsets are you using? Link to comment Share on other sites More sharing options...
dacheedah Posted July 28, 2014 Share #3 Posted July 28, 2014 did you check the volume of the IC , check mute button? Link to comment Share on other sites More sharing options...
MiCarl Posted July 28, 2014 Share #4 Posted July 28, 2014 Mute button shouldn't affect intercom. Since you can hear the audio system the problem isn't with the ear phones. You could have a problem with the microphones though. Easiest way to check is to try your headsets on a known good system or their headsets on your system. Link to comment Share on other sites More sharing options...
Donvito Posted July 28, 2014 Author Share #5 Posted July 28, 2014 J & M headsets, 20+ years old. Wires are deteriorating. Need a new set but whether or not the built-in intercom is working will determine what I purchase. That's why I'm looking for someone nearby with a working set so I can test out mine. Link to comment Share on other sites More sharing options...
