Ed S, SE Nebr Posted July 2, 2014 Posted July 2, 2014 I need to buy a cylinder hone to use when rebuilding the clutch MC. Probably should plan to do brakes, too, at some point. How small does it need to go? I saw a reference to 5/8" in another post. I recall the MCs on my KZ 750 being somewhere around that size, maybe smaller. Thanks eds
Flyinfool Posted July 2, 2014 Posted July 2, 2014 I know that the front brake master on an 88 is 14mm bore. The earlier years (I am not sure what years) is 1/2 inch. I do not know what size the clutch master is. On the brake master the bore size is cast into the side of the housing as either 1/2 or 14mm. Check your clutch master to see if it is marked.
Ed S, SE Nebr Posted July 2, 2014 Author Posted July 2, 2014 I know that the front brake master on an 88 is 14mm bore. The earlier years (I am not sure what years) is 1/2 inch. I do not know what size the clutch master is. On the brake master the bore size is cast into the side of the housing as either 1/2 or 14mm. Check your clutch master to see if it is marked. Thanks. This helps. I'm at work, half an hour from home, and was hoping to pick one up today. We're not working tomorrow and if I can save a trip into town... eds
dvuch1 Posted July 2, 2014 Posted July 2, 2014 I took my cylinders to Lincoln Clutch n Brake....labor was 35/each...I bought the rebuild kits on ebay....they hone if need be..I was happy and the dealer wanted 95 per cylinder just for labor...it's not hard to do yourself but didnt like my first attempt...Dave
Ed S, SE Nebr Posted July 2, 2014 Author Posted July 2, 2014 I took my cylinders to Lincoln Clutch n Brake....labor was 35/each...I bought the rebuild kits on ebay....they hone if need be..I was happy and the dealer wanted 95 per cylinder just for labor...it's not hard to do yourself but didnt like my first attempt...Dave More good info. Don't get in to Lincoln much, but this is good to know. Thanks, Dave. eds
bongobobny Posted July 2, 2014 Posted July 2, 2014 I use a 2 stone hone with the range of around 7/16" to 11/16" and unless the bore is REALLY corroded and pitted it works fine...
