eds Posted May 21, 2014 Share #1 Posted May 21, 2014 How much air pressure if any should the front forks have on second generation RSV Hannigan trike? Link to comment Share on other sites More sharing options...
bongobobny Posted May 22, 2014 Share #2 Posted May 22, 2014 Not much Ed, about 5 pounds each side give or take a few pounds. Link to comment Share on other sites More sharing options...
alwrmcusn Posted May 22, 2014 Share #3 Posted May 22, 2014 I believe the manual says a MAXIMUM of 7 (seven) pounds. I've tried 5 psi a couple of times and honestly could not tell any difference between that and zero psi. Your results may vary however. I was also specifically warned by the dealer NOT to use the high power air systems usually found at service stations etc. He said that they could quickly pump way more air than necessary and it could blow the fork. I bought a small bicycle pump to use. I've not tried it since I had the trike kit installed, so I think I'll give it another test and see what sort of results I get with the Easy Steer of the Hannigan setup. Link to comment Share on other sites More sharing options...
eds Posted May 22, 2014 Author Share #4 Posted May 22, 2014 Thanks guys, I was in the ballpark Link to comment Share on other sites More sharing options...
