rounce Posted December 18, 2006 #1 Posted December 18, 2006 I have been looking at ads and info on the net about battery desulfators. Given the long rest periods over our Canadian winters, I have had the experience of replacing batteries come spring and thereafter. Anybody have experience with these? They look like a great deal to me! Harvey
GeorgeS Posted December 18, 2006 #2 Posted December 18, 2006 Better yet, on your next replacement, get a Gell Cell, or, the Odyssey Dry Cell ( PC-680 ) The PC-680 puts out 3 times the cranking amps as any Lead Acid battery. They run 12.7 volts.
Freebird Posted December 19, 2006 #3 Posted December 19, 2006 I agree about the Odyssey. I've had mine for almost 4 years I think. Great battery. Also recommend a battery tender. Keep it topped off through the winter and it will last a lot longer.
Uturn Posted January 25, 2008 #4 Posted January 25, 2008 Can someone give me a good explaination how on this 'desulfator" works etc? Would that make my battery last longer? Rejuvinate it? Battery Viagra?? MIKE aka Uturn
flb_78 Posted January 25, 2008 #5 Posted January 25, 2008 Uturn said: Can someone give me a good explaination how on this 'desulfator" works etc? Would that make my battery last longer? Rejuvinate it? Battery Viagra?? MIKE aka Uturn My very basic understanding is that you take a complete electrically drained battery and do a reverse charge. This can cause all the crap that's built up on the lead plates to come off. You then clean the battery out by draining the acid and refill with fresh and it gives new life to an old battery. It's a lot of work and LEGAL disposal of the sulphuric acid can be a pain in butt. If you used very large expensive batteries, it would most likely be a viable solution, but for standard automotive and motorcycle batteries, new ones with warranties are cheaper. Once again, that's just a very, very, very, simplified, basic overview from my understanding and is not 100 percent correct.
cmiles3 Posted January 25, 2008 #6 Posted January 25, 2008 One method uses a high rate charge initially, trying to send the sulfate coating the lead plates back into solution. Don't try this at home, unless you like explosions.
