SARNA66 Posted March 14, 2014 #1 Posted March 14, 2014 getting ready for the season,trickled the battery, fired herr up. sounded a lil rough, when sitting on it ,pipe under left thigh pipe was cold. pulled off the rear plug wire, was getting jolted but made no difference in the way it ran. Okay helllllp. thanks ahead of time!!!
RedRider Posted March 14, 2014 #3 Posted March 14, 2014 Easy things first. Change the plug. $2 at O'reilly's. Check to see if the plug is wet indicating fuel is getting into the cylinder. RR
cowpuc Posted March 14, 2014 #4 Posted March 14, 2014 RedRider said: Easy things first. Change the plug. $2 at O'reilly's. Check to see if the plug is wet indicating fuel is getting into the cylinder. RR I am with Red Rider,, I would also double check the oil and make sure it aint contaminated with fuel just to be safe,, one little sniff in the crankcase will tell ya...
