MikeWa Posted February 14, 2014 Posted February 14, 2014 Ok I plugged the bike into the battery maintainer a few days ago and the maintainer never went to green. That is unusual because my tender normally goes green in less than an hour. So I began looking for the drain on the battery. First thing I found was my installed trunk light (led) was turned on. So I turned it off and the next morning the tender was still yellow. Hmmm. Then I remembered these bikes sometimes have a little problem with the cd changer drawing some voltage. So I unplugged the CD changer and within 2 hours the maintainer was green. I plugged the CD changer back in and reset the cartridge and all has been ok since. So this is just a reminder that the CD changer can occasionally cause a parasitic drain on the battery. Mike
Peder_y2k Posted February 14, 2014 Posted February 14, 2014 Excellent analytical problem solving. -Pete, in Tacoma WA USA
kevin-vic-b.c. Posted February 14, 2014 Posted February 14, 2014 things that make you say..... hmmmmm Kinda like me leaving the ignition turned on.... killed the battery by the time I was back to the bike next... no problem.... jump start.... the headlight died an hour later. hmmmm thanks:thumbsup2:
