how well do you know your motorcycles
hell yea
  • Replies 1.3k
  • Created
  • Last Reply
Top Posters In This Topic
I am crying 'foul'.
The 1978 CB750A didn't come with the Akront rims, it came with Comstar wheels. The 1978 had dual exhaust (4 into 2). The 1978 had cast aluminum passenger foot peg mounts, not the steel frame extensions shown. Your pictured bike is a 1976 with Akront rims and stock four into one exhaust and stock passenger foot pegs (in other words a 1976 frame). The seat is not 1976 stock but it was available as a Honda option.
And we can't check eBay ads from 2006 (where your pic was taken from).
Here's a 1978 Honda CB750A that sold at an auction in Vegas January 2014, survivor with 4000 miles.
images?q=tbn:ANd9GcR9nV7RjYK5di6hP_XVrTQiIILEUcotdHmqbIBBDcx1000M51QRhttp://forum.motorcycle-usa.com/attach.aspx/3896/750aleft%20small.JPG
Here's a 1976 CB750A with the optional seat, (although the seat appears to have added padding).http://media-cache-ec0.pinimg.com/736x/08/75/6a/08756adcc3e671e8801653dd2168e16a.jpg
Edited by Prairiehammer
Midalu FGR V6 motorcycle 2500 about 2012
Spec – FGR Midalu 2500 V6 – Concept Motorcycle
Engine type: 6 cylinders, 4-stroke, 90° V6
Displacement: 2440 cc (149.08 cubic inches)
Bore × stroke: 90 mm × 64 mm (oversquare – shortstroke)
Cooling system: Water cooled
Power: 239.97 HP (176.5 kW)
Torque: 200 Nm (20.39 kg-m)
Throttle: Cable operated
Valves
Valve train: SOHC, non-variable
Valves per cylinder: 4
Fuel and ignition
Sparks per cylinder: 1
Ignition type: Digital CDI
Compression: 9.9:1
Engine mounting: Transverse
Gear box: Manual
Final drive: Chain
Starter: Electric
Dimensions
Weight
Curb weight: 270 kg
Chassis and suspension
Frame type: Trellis frame
Front
Suspension: Cartridge
Brake: Twin Disk
Rear
Suspension: twin shock, Swingarm
Brake: Disk
Other
ABS available: No
Power-to-weight ratio: 0.65 HP/kg (1.53 kg/HP)
Number of riders: 2 persons
Big Toe. World's Tallest Rideable Motorcycle
http://www.roadcarvin.com/sites/default/files/images/IMG_4711.preview.JPG
http://farm1.static.flickr.com/167/402690660_9861cab9a2.jpg
http://smartercharger.com/wp-content/uploads/2011/01/Guinness_Certificate__Big_Toe11.jpg
1948: REDRUP RADIAL: Aircraft Engine Designer, Charles Redrup and his son John built the Redrup Radial, the cylinders were installed horizontally and the engine internals included an amazing system of cams and oscillating cruciform's to control the overhead valve gear. The frame was a pre-war Royal Enfield. The motorcycle was powered by a 248cc OHV three cylinder engine.
a project of Franck Savard that equipped different motors and there enduro versions
The guys who started the 2x2 idea on MX/SM bikes was the French Brothers Franck et Patrick Savard they used CR500,Husqvarna 510,KX500,YZ490 and TT600 Engines in both Dirt and Supermoto forms...
