Bert2006 Posted November 26, 2013 Share #1 Posted November 26, 2013 I am looking at installing a set of V&H Monster Ovals on a 2006 RSV. Are any adjustments required to tune carbs once these are on? Thanks ahead of time for your help! Link to comment Share on other sites More sharing options...
BratmanXj Posted November 26, 2013 Share #2 Posted November 26, 2013 If you only change the mufflers no carb adjustments are necessary. If you ALSO change the intake or head pipes then you would need to tune the carbs. You didn't ask, so I'll assume you've found the mounting brackets and clamp information already. You will need to expand the muffler intake slightly to fit over the head pipes. Link to comment Share on other sites More sharing options...
Bert2006 Posted November 26, 2013 Author Share #3 Posted November 26, 2013 If you only change the mufflers no carb adjustments are necessary. If you ALSO change the intake or head pipes then you would need to tune the carbs. You didn't ask, so I'll assume you've found the mounting brackets and clamp information already. You will need to expand the muffler intake slightly to fit over the head pipes. Thanks.....I think I can fabricate my own brackets but saw a link in one of the threads where they can be found. Also saw somewhere that the heat shield on the stock slip on can be reused to hide the connecting point by riveting it onto the new pipe, may do that if it works. Those V&H's are expensive though:mad: Link to comment Share on other sites More sharing options...
BratmanXj Posted November 26, 2013 Share #4 Posted November 26, 2013 A little bit of searching and you can find the diagrams for the adapter brackets. Bro-In-Law is a machinist so it took him 30 min at work to make some nice ones for me. I used the chrome clamps over the mounting flange on mine because I didn't want to hack up my stock mufflers, it was worth the $30 in case I ever go back or decide to sell the stockers. In your case the stock chrome "bell" might not match the Monster Oval shape so take some measurements before you hack the stock one up. I'll send you a PM with some more information....I just put a set of 105db HD Screaming Eagle Touring Pipes on mine about 2 months ago. Link to comment Share on other sites More sharing options...
mabeline Posted November 27, 2013 Share #5 Posted November 27, 2013 Bert If you do put them on, let us know how they sound at highway speeds. I've listened to You-tube videos and they sound like they have a nice rumble. But non of them are at Highway speeds. I cut the cone and moved the pipe over mod on my OEM mufflers. It's got a nice tone, but I'd like a deeper tone. Link to comment Share on other sites More sharing options...
BratmanXj Posted November 27, 2013 Share #6 Posted November 27, 2013 Buddy of mine has an '06 Screaming Eagle HD with a 103in and the same exact mufflers as mine. I have a nice burble at idle and up to 2,000 rpm then it tappers off, almost nothing at 65mph on the highway. His bike has a BIG bark and almost needing earplugs at 65mph. Knowing some similar HDs with Monster Ovals and how they sound at speed I'm sure on our V-4 it would be a very similar experience of quieting down at speed. Link to comment Share on other sites More sharing options...
DarrinGT Posted November 27, 2013 Share #7 Posted November 27, 2013 (edited) I am installing a set of Monster Ovals on mine this winter as well. Here is a set of used ones on ebay that aren't too expensive,,,yet,.. http://www.ebay.com/itm/USED-Vance-Hines-16755-Chrome-Monster-Ovals-for-1995-2014-Harley-Touring-NR-/151171036539?pt=Motorcycles_Parts_Accessories&hash=item23327ef57b&vxp=mtr Link was not working so I tried to fix it. Still not working...sorry. Edited November 27, 2013 by Freebird Link to comment Share on other sites More sharing options...
Bert2006 Posted November 27, 2013 Author Share #8 Posted November 27, 2013 I am installing a set of Monster Ovals on mine this winter as well. Here is a set of used ones on ebay that aren't too expensive,,,yet,.. http://www.ebay.com/itm/USED-Vance-Hines-16755-Chrome-Monster-Ovals-for-1995-2014-Harley-Touring-NR-/151171036539?pt=Motorcycles_Parts_Accessories&hash=item23327ef57b&vxp=mtr Link was not working so I tried to fix it. Still not working...sorry. Thanks for the link.. These are damaged like all of the others I am finding at a reasonable price. The good ones I found that are un-damaged go for around $550 to $750. Might as well buy new ones at that price. The search goes on................... Link to comment Share on other sites More sharing options...
DarrinGT Posted November 27, 2013 Share #9 Posted November 27, 2013 Thanks Freebird, When I posted they were at $200,..now there at $295,.. If I run into another set that looks good I will let ya know. Link to comment Share on other sites More sharing options...
gr8hwfan Posted January 13, 2014 Share #10 Posted January 13, 2014 I want to put monster ovals on my 06rsv and I understand about having to make a mounting bracket but what else is needed? Any info would be greatly appreciated. Link to comment Share on other sites More sharing options...
BratmanXj Posted January 13, 2014 Share #11 Posted January 13, 2014 I want to put monster ovals on my 06rsv and I understand about having to make a mounting bracket but what else is needed? Any info would be greatly appreciated. Pipes that fit any "modern" touring chassis harley. 2 mounting brackets, templates can be found in the tech forum. Muffler clamps, preferably chrome to cover the up the ends of the pipes. Link to comment Share on other sites More sharing options...
DarrinGT Posted January 13, 2014 Share #12 Posted January 13, 2014 I want to put monster ovals on my 06rsv and I understand about having to make a mounting bracket but what else is needed? Any info would be greatly appreciated. Here are the clamps that you need, Just used them mysef,.. http://www.ebay.com/itm/Royal-Star-Tour-Deluxe-Harley-Dav-Muffler-VTwin-Clamps-/250731286326?pt=Motorcycles_Parts_Accessories&hash=item3a60bfcf36&vxp=mtr Link to comment Share on other sites More sharing options...
pofarm Posted January 13, 2014 Share #13 Posted January 13, 2014 You can order the clamps cheaper from VTwin Manufacturing. I got my clamps from them. Link to comment Share on other sites More sharing options...
gr8hwfan Posted January 13, 2014 Share #14 Posted January 13, 2014 (edited) Thank you all very much for info ,it was very helpful. Edited January 13, 2014 by gr8hwfan Link to comment Share on other sites More sharing options...
gr8hwfan Posted March 25, 2014 Share #15 Posted March 25, 2014 (edited) Couple pics of how they look. Here is a link to how they sound on my bike. [ame] [/ame] Edited March 26, 2014 by gr8hwfan Link to comment Share on other sites More sharing options...
