hell yea Posted November 1, 2013 Posted November 1, 2013 will a transmishen out of an 89 1300 fit in an 83 and are the ratios the same ? aney help would be appreciated having 2 gear probs with the 83 and figer this may be tthe best way to sort it ?
Venturous Randy Posted November 1, 2013 Posted November 1, 2013 Yes, the 89 and 83 are the same. Another option is to go to a 2nd gen Venture with the wider spaced gears. Just make sure you can get the forks and shift drum with it. This might work good if you spend a lot of your riding on flat land and want a higher 5th gear. Stephen, are you in Australia or Oklahoma? RandyA
hell yea Posted November 1, 2013 Author Posted November 1, 2013 in Australia so the 89 will just drop in and fix the prob ?
Venturous Randy Posted November 1, 2013 Posted November 1, 2013 in Australia so the 89 will just drop in and fix the prob ? Yes, that should fix your problem. You need to change your location as it says you are in Oklahoma. RandyA
Venturous Randy Posted November 1, 2013 Posted November 1, 2013 ok will get onto that now Now you are being shown as being in Alaska. RandyA
hell yea Posted November 1, 2013 Author Posted November 1, 2013 it dusent give me an opshen not to pick a state ? so i have to be one untill i find out how to not
Prairiehammer Posted November 1, 2013 Posted November 1, 2013 When you get to the drop down menu for "state", select the blank spot above AK (Alaska). Hover your cursor over the blank spot, notice it is highlighted and then click this highlighted blank spot. Then, there will be no state selected.
Venturous Randy Posted November 2, 2013 Posted November 2, 2013 statless now:whistling: Hey, now everyone can see where you are from. RandyA
