terry hutchens Posted July 30, 2013 Share #1 Posted July 30, 2013 i know, i know, done a search on this and found a lot different opinions. my 84 whines the loudest @55mph, gets quieter around 60mph,complety stops when i pull in the clutch on the highway.according to the po's service records the transmission was rebuilt at 46,751 miles it now has 53,384. any ideas? thanks in advance! Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 30, 2013 Share #2 Posted July 30, 2013 My 83 has 162,000+ miles and has a slight whine sometimes, which is typical of square cut gears. I do believe that by going to Shell Rotella T oil that it is noticeably quieter. RandyA Link to comment Share on other sites More sharing options...
MiCarl Posted July 30, 2013 Share #3 Posted July 30, 2013 Primary gear noise is not speed dependent, it's RPM dependent. If it's the primary gear noise it'll do it in neutral. If the bike has to be in gear it'll be something in the drive line. Link to comment Share on other sites More sharing options...
KIC Posted July 31, 2013 Share #4 Posted July 31, 2013 It might just be trying to imitate a 2nd Gen owner.... whine..whine..whine...usually at lower speeds since they don't go that fast to begin with... Link to comment Share on other sites More sharing options...
terry hutchens Posted July 31, 2013 Author Share #5 Posted July 31, 2013 using castrol 20/50 Link to comment Share on other sites More sharing options...
easternrider Posted July 31, 2013 Share #6 Posted July 31, 2013 Not sure if it the same kind of "whine", but mine does it too. Mine is what I refer to a a "whistle trill". It sounds like someone is blowing lightly on a whistle, and no matter what gear I am in, it does it at 3000rpm. Link to comment Share on other sites More sharing options...
KIC Posted July 31, 2013 Share #7 Posted July 31, 2013 One thing that I have had on several bikes is a "whine" that is caused by the tires. If you "swerve" back and forth, to where the tire is off of the center, the noise momentarily goes a way until you are back straight. Long shot, but mine does it now with the tires I have. Link to comment Share on other sites More sharing options...
