kkent66 Posted July 30, 2013 Share #1 Posted July 30, 2013 I have a 2006 RSV 56k miles. Bike is running great no issues at all. Noticed the switch housing on the bike will move back and fourth about 1/4 - 1/2 inch. There are a few screws that hold the switch housing together and they are plenty tight. Is this normal to have this type of movement? I have not noticed until today. Again no issues with throttle or cruise control. Any thoughts would be greatly appreciated. Link to comment Share on other sites More sharing options...
steamer Posted July 30, 2013 Share #2 Posted July 30, 2013 It should not move. I think there is a pin that holes it in place. You can split it open and carefully pull it apart to look inside. I've had it apart a couple of times, no big deal. just take your time. Link to comment Share on other sites More sharing options...
kkent66 Posted July 30, 2013 Author Share #3 Posted July 30, 2013 Steamer - you were 100% correct - I removed the housing and the pin had slipped from the hole in the handle bar. Slipped the pin back in, replaced the two screws....good as new! Thanks for the help!!!! Link to comment Share on other sites More sharing options...
dacheedah Posted July 30, 2013 Share #4 Posted July 30, 2013 sweetness Link to comment Share on other sites More sharing options...
