playboy Posted April 19, 2013 #26 Posted April 19, 2013 So was I correct mike or totally out of the park ?
Godlover Posted April 19, 2013 Author #27 Posted April 19, 2013 eusa1 said: Had a nice talk with you on the phone mark Try and get at least 1 ride in before you trade it off!! Mike Thanks to for the suggestions! I thought I heard you say you would give me two grand as is!
eusa1 Posted April 19, 2013 #28 Posted April 19, 2013 $2k might work, does it come im the back of that unibody pickup???
Godlover Posted April 19, 2013 Author #29 Posted April 19, 2013 eusa1 said: $2k might work, does it come im the back of that unibody pickup??? That would be 3K!
Godlover Posted April 19, 2013 Author #31 Posted April 19, 2013 Godlover said: That would be 3K! Not yet, drained oil and it looked good. Will work on it when I return next week.
Godlover Posted April 22, 2013 Author #32 Posted April 22, 2013 Well, pulled plugs, tried to get it to turn over by pushing it amd popping clutch.....afraid the engine is stuck so going to try a few little things but doesn't look good. Two spark plug holes have carbon build up. Here is a picture of one.
Condor Posted April 22, 2013 #33 Posted April 22, 2013 Godlover said: Well, pulled plugs, tried to get it to turn over by pushing it amd popping clutch.....afraid the engine is stuck so going to try a few little things but doesn't look good. Two spark plug holes have carbon build up. Here is a picture of one. I'd try taking a mixture of acetone and oil together and pouring it into the cylinders. Let it sit overnight. Try popping the clutch again with the plugs out. We did that to an old frozen Triumph Bonneville a long time ago and it worked. I also freed up a frozen Mercury O/B. I think I might add a little Sea Foam to the mix just because.
eusa1 Posted April 22, 2013 #34 Posted April 22, 2013 Just poor a puddle of seafoam on the floor and park over it and see if it will soak it up and fix everything:whistling:
Godlover Posted April 22, 2013 Author #35 Posted April 22, 2013 Funny, going to try the coke thing. This isn't like a bike that has been sitting. It ran 30 days ago and that is the concern. I will fool around with it a bit more and then start to look for an engine. I got it at a price that I can replace the engine.
