Yamamike Posted June 1, 2012 Share #1 Posted June 1, 2012 I've read some old posts about this subject but wonder if there is something newer I've missed. To use my brake pedal, I have to raise my foot up off the footboard which does not provide much control of the brake pressure being applied. This is because the pedal is too far back. I'd like to be able to keep my heel on the board and the only solution I see is to lengthen the pedal three or four inches. Anyone out there have a different solution? Link to comment Share on other sites More sharing options...
09RSTD Posted June 1, 2012 Share #2 Posted June 1, 2012 Buy a 2nd Gen! :rotf: Link to comment Share on other sites More sharing options...
Yamamike Posted June 1, 2012 Author Share #3 Posted June 1, 2012 OH yeah well I just read a few posts from guys with the same issue on Gen2's so...so...so there! Ha...told you didn't I.......... Link to comment Share on other sites More sharing options...
Squeeze Posted June 1, 2012 Share #4 Posted June 1, 2012 You could dismount the Pedal from the Axle and relocate it at a lower Position. Just don't go too low, and check if the Master has a little Freeplay when the Pedal is not in use. Link to comment Share on other sites More sharing options...
Yamamike Posted June 25, 2012 Author Share #5 Posted June 25, 2012 Anyone out there with foot boards have photos showing the board/brake pedal set-up?? Link to comment Share on other sites More sharing options...
