GolfVenture Posted May 20, 2012 Posted May 20, 2012 On 91VR ?1) Whats the procedure in changing Anitfreeze. ?2) What brand is best suited and especially for the seals.
Snaggletooth Posted May 20, 2012 Posted May 20, 2012 This thread covers most the things involved. http://www.venturerider.org/forum/showthread.php?t=69229 Any antifreeze that is fine for aluminum should work for you. Mike
Condor Posted May 20, 2012 Posted May 20, 2012 Yep the link above covers most everything. I leave the cap off and the drain open and stuff a garden hose in the fill that is adjusted to about the same flow as the drain, and then let the motor idle for 10 minutes or so to flush out all the old coolant. Satisfies my paranoia....
spitfire9 Posted May 20, 2012 Posted May 20, 2012 Yep the link above covers most everything. I leave the cap off and the drain open and stuff a garden hose in the fill that is adjusted to about the same flow as the drain, and then let the motor idle for 10 minutes or so to flush out all the old coolant. Satisfies my paranoia.... Ooh good advise. Hadn't thought of that.
