Santa Hal Posted April 13, 2012 #1 Posted April 13, 2012 I cannot change the time clock on my pc from milatary time to regular time. What to do? Hal
rstacy Posted April 13, 2012 #2 Posted April 13, 2012 Assuming that you are running XP, go to control panel, go on Date, Time, Language, and Regional Options, click the item 2nd down in the list which says change the format of numbers...., click the time tab, go to time format and set it as h:mm:ss tt, the big H is 24 hr the small h is 12 click ok, and ok again. thats should do it for u. The method is slightly different in XP Home Edition. In Control Panel, go straight to Regional and Language Options Then click Customize next to the displayed language. Select the time tab and alter the format as above, i.e. HH for 24 hour, hh for 12 hour.
Owen Posted April 13, 2012 #3 Posted April 13, 2012 rstacy said: Assuming that you are running XP, go to control panel, go on Date, Time, Language, and Regional Options, click the item 2nd down in the list which says change the format of numbers...., click the time tab, go to time format and set it as h:mm:ss tt, the big H is 24 hr the small h is 12 click ok, and ok again. thats should do it for u. The method is slightly different in XP Home Edition. In Control Panel, go straight to Regional and Language Options Then click Customize next to the displayed language. Select the time tab and alter the format as above, i.e. HH for 24 hour, hh for 12 hour. So simple... :rotf:
Santa Hal Posted April 13, 2012 Author #4 Posted April 13, 2012 Got it fixed before I got your information. Halalmost there figured out. Thanks anyway. Have you done any riding latley Owen? Thinking of doing a bar b que run. Hal
SilvrT Posted April 13, 2012 #5 Posted April 13, 2012 Halmost There said: I cannot change the time clock on my pc from milatary time to regular time. What to do? Hal Give it back and get a civillian one...
Scooter Bob Posted April 13, 2012 #6 Posted April 13, 2012 Halmost There said: I cannot change the time clock on my pc from milatary time to regular time. What to do? Hal Time to join the military. You'd make a great seargent of the motorpool.
