TEW47 Posted November 21, 2011 Posted November 21, 2011 What is the beat way to lower the pedal? By looking at it I would have to remove the floor board, loosen the bolt on the brake shaft, rotate it forward and re-tighten the bolt. Then adjust brake light switch. Is there anything else I should do or have over looked? tew47
bongobobny Posted November 21, 2011 Posted November 21, 2011 ??? What exactly are you trying to do? You can adjust the position of the bake pedal with the adjusting link if that is what you are trying to do...
