seabeetom Posted October 19, 2011 Posted October 19, 2011 Picked up a Time-Out trailer from Tupelo over the weekend. LED lights, 5pin round connector. Question to U Hannigan Trikers---- How did you route the wiring from the connections under the seat to the trailer hitch??
kj5ix Posted October 31, 2011 Posted October 31, 2011 It ties in under the tour pac in a big white connector. Can be reached by pulling the left tire off, and you should see it. Most of mine have been 4 to 5 converted there.
seabeetom Posted November 2, 2011 Author Posted November 2, 2011 It ties in under the tour pac in a big white connector. Can be reached by pulling the left tire off, and you should see it. Most of mine have been 4 to 5 converted there. Tnx for the info George. I looked and there is no wiring or connector there or anywhere. Then called the installer, Huals Trikes in Cantonment, Fl., who said wiring was not there and was not part of the tow package option. Then called John @ Hannigan who said 'Yes indeed' the wiring was part of the tow package. Soooo, another example of the installers professionalism. I ended up tapping into the wiring under the driver seat and running my own harness to the back of the trike. Then come to find out thet the hitch ball was about 5" too low to mount the Time-Out Dart in a semblance of levelness. Had to get a 5" rise ball mount, and grind down the shaft so it would fit in the receiver. This whole Trike conversion by Huals has been nothing but a nightmare since day one.
Sylvester Posted November 2, 2011 Posted November 2, 2011 Call David Hannigan and let him know of your frustrations.
