jrsain Posted October 6, 2011 Posted October 6, 2011 I have an 07 RSTD with 21k and since I have owned it only 6 weeks I don't have a lot of info about what was done by the prior owner (original). So that being said I believe it to be stock, I know the exhaust is, I'm experiencing some slight decel popping. Is this a tuning issue that is a warranty item or is it normal?
dfitzbiz Posted October 6, 2011 Posted October 6, 2011 Check out the vacuum lines and caps that are located between the carbs (check out the tech section-carb sync for the pics). A leaking cap caused decel popping on my RSV. Also clean the system with SeaFoam. I use 1/2 can in a tank of gas. A carb sync may be in order. Good Luck. I'm sure others will chime in.
MiCarl Posted October 6, 2011 Posted October 6, 2011 Carbs out of sync will cause some popping too. That is a maintenance item.
