I am having a very noticeable rattle under the bike and I am trying to determine if it is a loose baffle. I have another collector that I had a sleeve welded on where one of the pipe connections had broke off and when I look into the muffler tube hole I can see what looks like a baffle. When I stick a foot long rod in and peck on the baffle, it is solid. When I pulled the right muffler off, where the knock seems loudest, and did the same thing on the collector on the bike, it also seems to be mounted solid. It there another baffle in there that I am not seeing or feeling that could be loose?
RandyA
RandyA
I have a similar rattle, and I have cut the collector open to check the baffle which is solidly in place.
Something else is rattling down there, and I'm not sure what it is.
Grrr!
I have the rattle in the collector and it went away for a while when I leaned ther bike over and gave the collector a good whack with a wooden hammer. But, its back and its drivingme crazy, but i want to make it thru until I put the bike away for the winter. then Ill have lots of time to work on it.
Brian
there is a thread here on how to fix it.
http://www.venturerider.org/forum/showthread.php?t=1002
lay bike on left side gently, preferebly on grass
take a grinder with a cutting disc and i did three cuts, each side and along the back
them i pried the metal tab open
there was one piece of metal baffle that almost fell out and the other side i took the cutting disc to it and removed the other piece.
then i pried the metal back to its original position
took the bike over to a local welding shop, layed the bike gently on its side again and he stitched up the opening that i had made
hope this helps
cheers, Scott
laying my bike on the side to fix the baffles isnt going to save me much work, as I have to pull the collector off anyway, to replace at least one exhaust gasket that is leaking too.
Briam
