shamlaw Posted June 11, 2011 Share #1 Posted June 11, 2011 Ok guys will the intercom cables comming from the amp to head set from a 99 work on the 92 venture as long as the cable from the 99 has the 90 degree angle on the end going into the amp:bluesbrother: Link to comment Share on other sites More sharing options...
Freebird Posted June 12, 2011 Share #2 Posted June 12, 2011 I believe the pin configuration is the same but I don't think the '99 has anything with the same connector that plugs into the amp. Link to comment Share on other sites More sharing options...
shamlaw Posted June 12, 2011 Author Share #3 Posted June 12, 2011 yea I saw some cable on Pin Walls site it looked to have the angle to fix the amp. think i will just attempt to repair mine its just the one end bad Link to comment Share on other sites More sharing options...
