bkuhr Posted February 14, 2011 Posted February 14, 2011 (edited) With tire changer I made. Have had for long time auto changer simular or same as HF. pic 1 Only permement mod was to weld a 5/8 nut to top. pic 2 Cut hex to fit 5/8 nut in 1/4 plate and welded to old 14-15 auto rim(anti rotation). pic 3 Just set rim over nut on stand. pic 4 Tread 5/8 all thread into nut to tight(notice hole at top for screwdriver shaft). pic 5 Another piece of 1/4 plate with 5/8 hole and 5/8 jam nut secures auto rim to stand. pic 6 Split rubber tube on edge of auto rim protects MC wheel. pic 7 MC wheel placed down all tread. pic 8 5/8 washer and another nut secures MC wheel to auto rim/stand. pic 9 Piece of plastic water pipe protects all thread-threads when tire spoons pried against. pic 10 Final view. pic 11 Also built balancer with lumber. Appears to work, same spot of existing tire/wheel always stops same. Now I just need to commit to do it. Edited February 15, 2011 by bkuhr
MiCarl Posted February 15, 2011 Posted February 15, 2011 I have a suggestion for an improvement. I used to use a similar set up, except it was mounted on a bench. I also put a hole in a length of 2x2 and used a nut to run it down the all thread. I could tuck the end of a spoon under it to hold the starting point as I worked my way around. I could also put the spoon out under the end to hold the bead down as I worked a new tire on. http://xjbikes.com/modules/coppermine/albums/userpics/10730/thirdhand2.jpg It's been awhile since I used it. I think that extra block probably gave me something to tighten against so it didn't spin or cock up. I was able to get rid of that pesky third arm and hand that made it really hard to buy shirts.
Venturous Randy Posted February 15, 2011 Posted February 15, 2011 One area that some people have a problem with and that is the initial breaking down of the tire away from the bead. I have found that a vise works good at times. The other thing is use plenty of lube like soapy water to take the tire off. RandyA
