ediddy Posted November 24, 2010 Share #1 Posted November 24, 2010 Can you jump a venture with jumper cables hooked to an automobile battery? Link to comment Share on other sites More sharing options...
Freebird Posted November 24, 2010 Share #2 Posted November 24, 2010 Yes you can. No problem at all. Most people would recommend that the car not be running though. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 24, 2010 Share #3 Posted November 24, 2010 Yes you can. No problem at all. Most people would recommend that the car not be running though. I make a small set of jumpers for the bikes. Just use one of those 6 or 9 ft extenison cords you can get for a couple bucks at Dollar Stores cut off ends and put electrical clips on them. I just feel better not throwing all that juice to a bike system. I may not be right in this but I don't think that small cord would carry enough to hurt system. Link to comment Share on other sites More sharing options...
Sylvester Posted November 24, 2010 Share #4 Posted November 24, 2010 12 volts is 12 volts and that is all. You can get it anyway you want. Get a bunch of D cell batteries it you want. Amps are something different and Freebird was right with don't run the engine. Link to comment Share on other sites More sharing options...
davecb Posted November 24, 2010 Share #5 Posted November 24, 2010 12 volts is 12 volts and that is all. You can get it anyway you want. Get a bunch of D cell batteries it you want. Amps are something different and Freebird was right with don't run the engine. Also: It is best to hook up the ground cable to the bike itself...Not the battery... Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 24, 2010 Share #6 Posted November 24, 2010 I thought the heavier the cables the more amps they carried. Link to comment Share on other sites More sharing options...
Sylvester Posted November 24, 2010 Share #7 Posted November 24, 2010 I thought the heavier the cables the more amps they carried. Dead on Y D, but you don't want the high charge rate of the car alternator. That is why I just use the car battery without the engine running. Link to comment Share on other sites More sharing options...
Yammer Dan Posted November 24, 2010 Share #8 Posted November 24, 2010 Not the 1st time I've been told I was wrong. Link to comment Share on other sites More sharing options...
