uechi kid Posted October 11, 2010 Posted October 11, 2010 Back in July I bought a chrome Stebel air horn from Hornblasters.com. I also bought the Carbon One wiring harness and mounting bracket. Last weekend I finally got around to install the horn but the horn I received was the Nova Chrome version. This horn has a chromed plastic cover that looks great but because of the cover it's a little larger. Needless to say it doesn't fit in the space where the factory horn goes without some modification. The first thing I had to do was add a spacer (1/4") between the mount on the back of the horn and the Carbon One mounting bracket. Then I had to trim some of the plastic cover from the upper right side of the compressor so the horn wouldn't touch the engine. I used a dremel tool . Lastly I had to change the clips on the wiring harness that go the the horn. This horn has the electrical connections coming out of the bottom of the compressor. I changed the wiring harness connectors from straight to 90 degree other wise the wires would have touched the pipes. Moral to the story, when you by parts online make sure you get what you thought you ordered. Also, if you are going to add a Stebel horn make sure you don't get the Nova version.
Lone Eagle Posted October 12, 2010 Posted October 12, 2010 HEY, you got that installed - good on you, bud! I can "hear you now"
uechi kid Posted October 12, 2010 Author Posted October 12, 2010 Yep, finally got it done. What should have been an easy hour took me about five hours and a trip to the hardware store and Radio Shack.
