Color01 Posted November 2, 2007 Share #1 Posted November 2, 2007 I bought 6 weeks a go a 2003 Midnight Venture with 4000 miles. When I ride in the city, I noticed that it starts popping at regular interval through the exhaust system when I close the gas throttle…I know the original owner removed the exhaust baffles and the bike sounds great .. but I hate that regular popping through the exhaust system. Is there anything that I can do ? Link to comment Share on other sites More sharing options...
Bubbajbi Posted November 2, 2007 Share #2 Posted November 2, 2007 This should explain what to do. You have to plug the AIS system. http://www.venturerider.org/forum/showthread.php?t=485 Link to comment Share on other sites More sharing options...
WilCruise Posted November 2, 2007 Share #3 Posted November 2, 2007 Yup! Many have had luck just synching carbs to get rid of it. Many more of us have still had some popping after that. This is caused by the AIS system used to meet emission requirementss. It's possible to modify it so you don't get the backfires. Check out how here: http://www.venturerider.org/forum/showthread.php?t=485 Link to comment Share on other sites More sharing options...
Pilot Posted November 2, 2007 Share #4 Posted November 2, 2007 How did you come across a 03 with only 4k miles on her? She's brand new... As far as you question goes, yup it's the AIS. Link to comment Share on other sites More sharing options...
Color01 Posted November 2, 2007 Author Share #5 Posted November 2, 2007 Thank you for the Advice . I will check in the next few weeks for the AIS System . Pilot .. How did you come across a 03 with only 4k miles on her? She's brand new... I found the bike on Ebay .. and everything on the bike looks like New. Link to comment Share on other sites More sharing options...
BradT Posted November 3, 2007 Share #6 Posted November 3, 2007 Yup! Many have had luck just synching carbs to get rid of it. This should do it but may require the AIS to be removed or plugged. I never plugged mine but if I get higher altitude it will pop. When I ride around home and it starts popping I know it is time to sync the carbs. Does not happen often i just sync them in the spring. But if the choke is on slightly it will pop. Brad Link to comment Share on other sites More sharing options...
Guest Bigin Posted November 4, 2007 Share #7 Posted November 4, 2007 I don't own an RSV but on my 89 VR could not get the popping Around 3000 rpm and lower to stop with all the recomendations above, until I opened my pilot jets beyond the recommended 2.5 turns, or what ever it is depending on who you talk to or read. Mine are in the 3.5 to almost 4.5 turns open depending on the cylinder using my ear to adjust each after a carb synch, then rechecking the sync after. It has not hurt mileage, which is 40-44 mpg if conservatively ridden. I dont have stock mufflers, have the Jardines, can't confirm what previous ownere may have done to carb jetting, maybe this why? Runs beautiful since opening them up. It is easy to do and undo if doesn't help Link to comment Share on other sites More sharing options...
High Plains Drifter Posted November 4, 2007 Share #8 Posted November 4, 2007 Or you may end up rejetting. I have Baron's Nasty Boy slip-ons. After plugging the AIS, and turning the pilot jets up to 8 or 9 turns out, I gave up and rejetted my carbs. I wish I'd just done it to begin with and saved myself several months of aggravation. Drifter Link to comment Share on other sites More sharing options...
V7Goose Posted November 5, 2007 Share #9 Posted November 5, 2007 Do a search on my posts - around mid summer of this year . . . I'd put serious money on your problem being cracked and hardened rubber caps on the two intake manifold nipples. If you have any kind of a vacuum leak, you will have this problem. Easy fix without messing with your emissions controls. However, an old bike siting for so long with so few miles can have quite a few things that contribute to this problem. Carbs not working perfectly (gummed up) will definitely exacerbate it - better run some Sea Foam through it. Fouled plugs also - easy and cheap to change. Goose Link to comment Share on other sites More sharing options...
