TonyLudwick Posted September 22, 2010 #1 Posted September 22, 2010 Good Afternoon All, How much play should the top rear shock bolt have in it? I decided to inspect the swing-arm assembly before I start to put her back together, and discovered play when I raise the swing-arm up and down. Is there a bushing in there that can be worn out already, or is this normal. I would guess it is probably somewhere between 1/32nd and 1/16th of an inch, and appears to be concentrated on the top rear shock connection. Have any of you experienced this?
