star4772 Posted August 8, 2010 Posted August 8, 2010 2008 RSTD Question I let bike sit for 5-6 weeks and when I got home and fired it up after turning the gas back on (I think it was off ) it fired up first time and it seem to run only on 2 cyc. and no power. Could it be cause I left it on the side stand and gas drained into the cyclinder? Now after a mile or 2 runing it and blowing it out it seems to be fine and no missing or bogging down or anything. What do you all think. Joe star4772 :confused24:
slick97spirit Posted August 9, 2010 Posted August 9, 2010 bumping this back up so it doesn't get overlooked
Yammer Dan Posted August 9, 2010 Posted August 9, 2010 (edited) If it is going to be sitting make sure you have sea-Foam of Sta-Built or something like that in it. Edited August 9, 2010 by Yammer Dan
star4772 Posted August 9, 2010 Author Posted August 9, 2010 If it is going to be sitting make sure you have sea-Foam of Sta-Built or something like that in it. I put some Sta-bil in every time I let it sit.
Guest scarylarry Posted August 9, 2010 Posted August 9, 2010 Was it full? Could have been moisture in it... If it is running fine now, ride like you stole is all I can say
skydoc_17 Posted August 9, 2010 Posted August 9, 2010 Without knowing if it IS actually running on less than 4 cylinders and not nowing if it is the high side two cylinders or the low side two that appear to not be firing it's basically a crap shoot. You say an 08', 12 miles, 12,000 miles??? Have you ever put a set of plugs in this bike, Pulled the current set out and looked at them?? Is the low side exhaust set smoky when you first fire it up? I have seen MORE than one person foul a set of plugs getting heavy with Seafoam/Sta-Bil. Carbs. Synced? Float Level checked? If it turns out to be both rear cylinders not firing, it could be coils, Fuel Filter, A bit more info on the condition of some of the perishable items would allow someone to point you in a direction. Earl
star4772 Posted August 9, 2010 Author Posted August 9, 2010 Without knowing if it IS actually running on less than 4 cylinders and not nowing if it is the high side two cylinders or the low side two that appear to not be firing it's basically a crap shoot. You say an 08', 12 miles, 12,000 miles??? Have you ever put a set of plugs in this bike, Pulled the current set out and looked at them?? Is the low side exhaust set smoky when you first fire it up? I have seen MORE than one person foul a set of plugs getting heavy with Seafoam/Sta-Bil. Carbs. Synced? Float Level checked? If it turns out to be both rear cylinders not firing, it could be coils, Fuel Filter, A bit more info on the condition of some of the perishable items would allow someone to point you in a direction. Earl Bike bought new last month and 1/2 ago I only have 800 miles on it. It was a NOS left over. I dont know what cyclinders were not firing but so far everything seems to be running fine now. We will see what happens tomorrow. Thanks Joe
Dano Posted August 9, 2010 Posted August 9, 2010 I personally think you diagnosed it yourself. At 800 miles the rings aren't fully seated but it will still trap gas if a carb was leaking a bit. After a few moments the cylinder will clear itself and things will be back to normal. If it doesn't happen again, that's probably what it was. Dan
Snarley Bill Posted August 9, 2010 Posted August 9, 2010 i would say you have some clogged pilot jets. take it in on warranty. it's a major job relacing them.
gidzhome Posted August 9, 2010 Posted August 9, 2010 Joe, what were you doing letting it sit for 5 weeks in the first place ??
star4772 Posted August 9, 2010 Author Posted August 9, 2010 joe, what were you doing letting it sit for 5 weeks in the first place ?? otr truck driver last time home was july 4th now home for a week. I know it sucks.
