LLonearth Posted July 15, 2010 Posted July 15, 2010 I finally found the speedo gear for the front axle and need to replace the old one. Are there any shortcuts? The bearings were replaced last year and I only want to get this different speedo gear in place to see if that fixes my speedometer and cruise problem. Thanks for any help. 1987 VR. Larry
MiCarl Posted July 15, 2010 Posted July 15, 2010 No shortcuts. Gotta pull the axle and move the wheel about 2" at which point it'll just drop out. I think you can probably leave the brake calipers on since you're shouldn't need to get the rim and tire past them.
