titansedriver Posted June 4, 2010 #1 Posted June 4, 2010 I have noticed a couple of times the past 2 weeks that my cooling fan will just arbitrarily come on while my bike has been sitting in the garage for a couple days--If I disconnect the battery ground and reconnect everything is fine (the fan shuts off)---Do I have a bad relay or am I missing something??
Venturous Randy Posted June 4, 2010 #2 Posted June 4, 2010 Sounds to me like you have something grounding out. RandyA
dingy Posted June 4, 2010 #4 Posted June 4, 2010 titansedriver said: I have noticed a couple of times the past 2 weeks that my cooling fan will just arbitrarily come on while my bike has been sitting in the garage for a couple days--If I disconnect the battery ground and reconnect everything is fine (the fan shuts off)---Do I have a bad relay or am I missing something?? If the fan is wired per the schematic, it should not have power to it unless the key is in the 'On' position. Schematic link below. http://www.venturerider.org/wiring/86-89%20Yamaha%20Venture%20Simplified%20Circuit%20Diagram%20Rev%20D.pdf Gary
