On my way to work, I noticed my dash lights weren't workin
then I pulled over & saw my head light & Signal lts weren't working.
I got to work and when I turned the bars to the left it all came
back on.
Is there a connection I should look at to
find the problem?
often when folks install the wires for the passing lamps, they will run it near the steering stops where it can get pinched and damaged.
turn the bars all the way too the stops and check there first.
mike.
It was an easy fix.
I had taken the fuel tank off a few days before to run an intercom wire, so that's the first place I looked. Apparently I had inadvertently disturbed a connector and it was just barely together. I couldn't tell it was loose until I pulled on each connector. When I pulled on this one it fell apart.
I plugged it back in and everything works.
