Tarl Posted April 1, 2010 #1 Posted April 1, 2010 I have an 83 VR and tonight I thought I would check the coolant level in the radiator. I can only get the cap undone about 1/3 of a turn. I tried pressing down while turning counter clockwise, but it just won't come off. Am I missing something?
Yammer Dan Posted April 1, 2010 #2 Posted April 1, 2010 Should work. Make sure it is cold. Takes a pretty good tug up after you turn.
Rocket Posted April 2, 2010 #3 Posted April 2, 2010 Tarl said: I have an 83 VR and tonight I thought I would check the coolant level in the radiator. I can only get the cap undone about 1/3 of a turn. I tried pressing down while turning counter clockwise, but it just won't come off. Am I missing something? Sometimes the rad covering trim will interfere with removing the rad cap. I filed down the area, that caused problems with mine. Just try initially, removing the trim cover & see if the cap will come off normally.
barend Posted April 2, 2010 #4 Posted April 2, 2010 could you just look at the overflow reservoir under the right fairing cover??
CaptainJoe Posted April 2, 2010 #5 Posted April 2, 2010 I haven't looked at mine but some bikes have a little phillips head screw on the cap you must loosen. Will check tomorrow.
barend Posted April 2, 2010 #6 Posted April 2, 2010 not on a '83, like Rocket said, it's the cover that interferes. Take the trim pieces of on the side (the ones with the reflector and you can rotate the rad cover forward (top down) and then gently lift that sucker up to clear the pins. If you try to pull it straight out you'll brake the hanging tabs and it will be a tad harder to re-install. Have fun
Tarl Posted April 2, 2010 Author #7 Posted April 2, 2010 barend said: not on a '83, like Rocket said, it's the cover that interferes. Take the trim pieces of on the side (the ones with the reflector and you can rotate the rad cover forward (top down) and then gently lift that sucker up to clear the pins. If you try to pull it straight out you'll brake the hanging tabs and it will be a tad harder to re-install. Have fun Thanks for all the help folks. I'll have a go at it again tomorrow.
Condor Posted April 2, 2010 #8 Posted April 2, 2010 barend said: not on a '83, like Rocket said, it's the cover that interferes. Take the trim pieces of on the side (the ones with the reflector and you can rotate the rad cover forward (top down) and then gently lift that sucker up to clear the pins. If you try to pull it straight out you'll brake the hanging tabs and it will be a tad harder to re-install. Have fun I don't think it's all '83's. I don't remember having a problem taking mine off last summer when I flushed the system??
Guest seuadr Posted April 2, 2010 #9 Posted April 2, 2010 i have an 87 mk2 and the same problem. like mentioned before, it seems in some instances the cover interferes with the cap. i filed mine down too and works fine now
