Owen Posted March 11, 2010 Share #1 Posted March 11, 2010 Thought I would share this. This happened to me about half way through our 350 miles of rain on the way to Bogalusa. The next day I went through all the connections and found them to be still clean, dry of water and greased with dielectric grease just as I had done a year ago. Symptom: Any audio source from speakers is severely distorted. The distortion is so bad you can not understand anything. This initially occurs at a volume setting of about 18 or above which is my normal cruzin' level. If the level is kept around 10 or so, it sounds ok for a while but eventually becomes distorted. All the while the head set audio is clear. The dealer has ordered a replacement audio amp unit (warranty) after confirming with Yamaha that is is a known symptom. Just as a side note, the retail cost for the replacement is $1400. Link to comment Share on other sites More sharing options...
AKRefugee Posted March 13, 2010 Share #2 Posted March 13, 2010 Got mine in the shop going through that right now. Not only got them to replace the amp but they are also replacing all 4 speakers. Link to comment Share on other sites More sharing options...
Kregerdoodle Posted March 13, 2010 Share #3 Posted March 13, 2010 well at $1400.00 if mine goes south, there is gonna be alot of singing goin on....lalala..I may sing to ya`ll over the CB...if that still works!! Link to comment Share on other sites More sharing options...
LilBeaver Posted March 13, 2010 Share #4 Posted March 13, 2010 ... lalala..I may sing to ya`ll over the CB...if that still works!! :yikes::yikes: Link to comment Share on other sites More sharing options...
