pegscraper Posted October 8, 2007 Posted October 8, 2007 Yeah, but the first time out of the box that engine made 290 hp. And they detuned it what, five times to get down to only 210? Let's put this engine in the Venture now and kick the crap out of the 'wing. It appears you've found the new V Max site.
KiteSquid Posted October 8, 2007 Posted October 8, 2007 I'll fourth that!!!!! 210+ HP in a Venture would be SWEET!!!! Fuel injection and variable valve timing that the Otodama engine has would be WONDERFUL in my next Venture!!! Add traction control and punch the HP up to the original HP of 295 HP!!! IF you take the current weight of the Venture of 807 LBS and divide it by 210 HP you get 3.8428571428571428571428571428571 LBS per HP!!!!!!!! OR, IF you take the current weight of the Venture of 807 LBS and divide it by 295 you get 2.7355932203389830508474576271186 LBS per HP!!!!!!!! HANG ON!!!!! 1800 CC = about 110 CID, or the same size engine on the Screamn' Eagle Ultra Classic, but with more HP and probably a little less than the $$$$$ H-D sells it for.....
