kbran Posted October 23, 2009 #1 Posted October 23, 2009 Just put an e3 tire on the 86 and have been having fits getting the wheel back on. I get it back in the splines on the pumkin but do not have enough room after putting the caliper bracket or push rod back on to place the washer between it and the swingarm. Can't figure out what I am doing wrong. HELP PLEAE. AND THANKS.
PastorPaul Posted October 23, 2009 #3 Posted October 23, 2009 You have to hold your mouth just right and tilt your head to the correct angle. A few choice words help also. lol:rotfl:
Yammer Dan Posted October 23, 2009 #4 Posted October 23, 2009 You gotta put the axel in there or it will fall off every time!! Been there done that!! What did you do wrong ?? Spacer in wrong place??
kbran Posted October 24, 2009 Author #5 Posted October 24, 2009 Yammer Dan said: You gotta put the axel in there or it will fall off every time!! Been there done that!! What did you do wrong ?? Spacer in wrong place?? The inner spacer had fallen down causing the outer spacer next to the pumking to be to far out:whistling:
Marcarl Posted October 24, 2009 #6 Posted October 24, 2009 kbran said: The inner spacer had fallen down causing the outer spacer next to the pumking to be to far out:whistling: Must have been my fault then,,,,,,,I've been told that I'm FAR OUT.
Yammer Dan Posted October 24, 2009 #7 Posted October 24, 2009 I think I've done that one too. Changed my rear tire once and spent almost a whole day getting the wheel back on. We'll just blame it on Carl!!
Jrichard Posted October 24, 2009 #8 Posted October 24, 2009 kbran said: The inner spacer had fallen down causing the outer spacer next to the pumking to be to far out:whistling: Kenny-----been there,done that!!!!!!!!!------all it usually takes is a bit of lookin and makin Men sounds??????
BigBoyinMS Posted October 24, 2009 #9 Posted October 24, 2009 I have never had a problem with the wheel... but the first time I did a drive line lube it took me ALLLLLLLLLLLLLL freakin' day to stab the driveshaft back in. I was just aggravated I guess 'cause since then it takes 2 seconds.
