Need help with RSV wiring schematic
I am near completion on the RSV wiring schematic.
I have a number of questions about it that I am unable to check since I do not have A RSV.
What I need is someone that can look at a wiring harness on or off of bike and check these.
They are listed below.
If it would help I could email anyone interested in helping a copy of schematic.
I would like to get as many of these questions resolved prior to posting finished version.
There may be a prize for most needed answers
:think:
#1 Rear speakers only show 2 wires, if stereo rear speakers should be 4
Answered by YamaHamer 10/23/09
:bowdown:
#2 two of six wires from MCU to front radio remote go thru connector D, why just 2
#3 Is carb heart ground shown correct or do grounds all connect to Carb ground connector.
#4 Wire colors into fan noise filter conflict between what connectors indicate & indicated wire color.
#5 Rear Aux outlet positive wire color to fuse, Br/R or Br/B, wire has each on opposite ends
#6 Is Y/W wire color correct in rear brake switch, incoming cable shows Y/L
#7 Color of wire inside handle bar control from Cruise Control Switch to Hazard Switch, not marked on schematic
#8 Is Y/B wire correct color in clutch switch, incoming cable shows Y/W
Answered by BuddyRich 10/23/09
:bowdown:
#9 Is W wire correct color in PTT switch, incoming cable shows W/L
#10 PTT circuit problem….Harness connector legend does not show a W or a W/L wire going thru it, PTT circuit is indicated as going thru this connector though. MCU diagram indicates it is W/Y at connector but on other ends, indicates W/L at MCU and at push button it shows being a W, on cable going into push button it is W/L. Only one wire on schematic is W/Y, from MCU to Front Control & this does not indicate going thru D connector
#11 Is L/B wire correct color in dimmer switch, incoming cable shows R/Y
#12 Wire connector E, can’t locate Br/W terminal, only logical place is in wire from flasher relay to turn signal switch
#13 Wire connector D, can’t locate Y/R terminal, only Y/R at 2 places 1st out of cruise control relay, 2nd from flasher relay to turn signal switch.
Edited by dingy
Marked of answered questions
