elmicko Posted September 27, 2009 Share #1 Posted September 27, 2009 I've had a problem with my 86 VR where the signal lights were turning off way too quickly (sometimes after two or three blinks). One of my buddies helped me look at it a few weeks ago and we found out it was losing ground and cutting off before it was supposed to. After pricing replacement switches for a few weeks I decided to try something today. I ran a wire from the ground side of the fuse box through the cable channel in the left handle bar and into the switch. There is a metal plate inside the switch just behind the control. I played around with my wire to find where the plate needed the ground and soldered the wire in place. I have to manually turn my signal light off now after I make a turn, but I feel a whole lot safer now that I don't have to worry about it turning off at the wrong time. Not a hard fix if I could do it. Thought someone else may be having the same problem. Link to comment Share on other sites More sharing options...
Ozlander Posted September 27, 2009 Share #2 Posted September 27, 2009 That is what is now called a Presidential Solution. Link to comment Share on other sites More sharing options...
Owen Posted September 28, 2009 Share #3 Posted September 28, 2009 That is what is now called a Presidential Solution. :rotf::rotf::rotf: Link to comment Share on other sites More sharing options...
