dkip Posted July 18, 2009 Posted July 18, 2009 I'am interested in getting a stebel horn for my 2006 RSTD and was wondering where other members got theirs,and if any Canadian members now of a place in Ontario were they are available or do I just have to order online. Also would I better off to just get the horn and buy a relay and wire needed myself. Thanks dkip
GuthDaddy17 Posted July 18, 2009 Posted July 18, 2009 I got mine from BikerHiway and was happy with the purchase but DO NOT buy the "plug and play" it does not plug and play (maybe for cars) Use Carbon One's adaptor and relay and follow the directions here online and its really easy.
LilBeaver Posted July 18, 2009 Posted July 18, 2009 For what it is worth, I looked all over town (where I live) and could not find the horn anywhere. I found a few that appeared comparable (BadBoy horn at harbor freight) but I went ahead and just ordered the Stebel online. I also ended up wiring it up myself. Wire and the connectors are cheap, and the horn comes with a relay (although I did not end up using the relay that came with it). To mount it I ended up using a 2" L bracket and it worked fine... It doesn't look quite as good as it would had I used a Carbon_One bracket though. Good luck!
Bigfoot Posted July 18, 2009 Posted July 18, 2009 I got mine from BikerHiway and was happy with the purchase but DO NOT buy the "plug and play" it does not plug and play (maybe for cars) Use Carbon One's adaptor and relay and follow the directions here online and its really easy. Ditto. As a matter of fact this could have been my post. Do a search under members and find Carbon One. He makes the adaptors.
dkip Posted July 18, 2009 Author Posted July 18, 2009 Thanks everybody sounds like I might as well bite the bullet and order one on line. I will also look into carbon ones adapter dkip
wes0778 Posted July 19, 2009 Posted July 19, 2009 I got mine from Biker Highway and also ordered the STEBEL install kit. With that and the Carbon One bracket the install was a snap.
