Thom Posted September 4, 2007 Share #1 Posted September 4, 2007 i installed the brake strobes and headlite strobe , i put 2 in the trunk running lites and 2 in the taillite , i used the 4 strobe lite with the sticky pads for the back and the 2 strobe lite for the front had drill hole for them and glue them in . made a daytona run yesterday , works great , all the cages stay off my butt and nobody cut me off and 1 trooper gave me a thumbs up . all for less than 50 bucks thanks , randy :thumbsup: Link to comment Share on other sites More sharing options...
Venturous Randy Posted September 5, 2007 Share #2 Posted September 5, 2007 Glad to hear that you did that. I strongly believe we do not have enough brakelights. I have also added one more light. I got an LED unit that is about four inches long that has six lights in it. I installed it right under the rack on the trunk and it works as a 3rd brakelight type thing, up high. I can either set it to come on all six bulbs at once or go from side to side with the two on the left coming on, then the two in the middle coming on as the ones on the left go off, then the two on the right comes on as the center two go off, then it sweeps back across to the left side again. It is very noticable. I also fixed the strobes inside my brakelight. RandyA Link to comment Share on other sites More sharing options...
Thom Posted September 6, 2007 Author Share #3 Posted September 6, 2007 ok , where did git that lite bar ? i got 1 coming from jcw but it is not the type you have , and the wire less helmet brake lite . thom Link to comment Share on other sites More sharing options...
hdroyer Posted September 6, 2007 Share #4 Posted September 6, 2007 I like to know what was used for the brake and headlite strobe and were you purchised them. I would like to do somthing like this to my 83 1Gen. Dale i installed the brake strobes and headlite strobe , i put 2 in the trunk running lites and 2 in the taillite , i used the 4 strobe lite with the sticky pads for the back and the 2 strobe lite for the front had drill hole for them and glue them in . made a daytona run yesterday , works great , all the cages stay off my butt and nobody cut me off and 1 trooper gave me a thumbs up . all for less than 50 bucks thanks , randy :thumbsup: Link to comment Share on other sites More sharing options...
Thom Posted September 7, 2007 Author Share #5 Posted September 7, 2007 autozone , i use the 4 strobe kit for the brakes 24.99 and 2 strobe for the head lite 14.99 thom Link to comment Share on other sites More sharing options...
