Dragonslayer Posted June 10, 2009 Share #1 Posted June 10, 2009 I'm finally getting around to installing the new to me final drive pumpkin I snagged from Lonestarmedic and thought it would be wise to lube the shaft before sticking it in. Question is: How do you disconnect the shaft from the pumpkin end to lube it? Link to comment Share on other sites More sharing options...
Dano Posted June 11, 2009 Share #2 Posted June 11, 2009 That shaft end is lubed through the final drive gear oil, a step-up from the MK1's. Don't pull it out or you'll damage the seal....... Dan Link to comment Share on other sites More sharing options...
Dragonslayer Posted June 11, 2009 Author Share #3 Posted June 11, 2009 That shaft end is lubed through the final drive gear oil, a step-up from the MK1's. Don't pull it out or you'll damage the seal....... Danthanks Link to comment Share on other sites More sharing options...
