bossman Posted September 3, 2007 Posted September 3, 2007 Greetings, I was hoping someone could point me in the right direction. I have a 86 Royale. I have been noticing lately when i goose the throttle their is a rattleing noise seems to be coming from underneath, or when I am going through the gears I hear it also. Checked bolts, fluids all ok. It is more noticable on the left side. Other then that it runs fine. Am thinking of going to Las Cruces in a couple of weeks . I was wondering if it is something I should be concerned with or if it could wait till I returned. Thank you . bossman:confused24:
Rocket Posted September 3, 2007 Posted September 3, 2007 Greetings, I was hoping someone could point me in the right direction. I have a 86 Royale. I have been noticing lately when i goose the throttle their is a rattleing noise seems to be coming from underneath, or when I am going through the gears I hear it also. Checked bolts, fluids all ok. It is more noticable on the left side. Other then that it runs fine. Am thinking of going to Las Cruces in a couple of weeks . I was wondering if it is something I should be concerned with or if it could wait till I returned. Thank you . bossman:confused24: From my initial impression on reading this post: I think you have a busted weld holding your exhaust baffle in place. It is not a must do right now, but the sound may get on your nerves. There are instructions here, on the repair. http://www.venturerider.org/forum/showthread.php?t=1002
SaltyDawg Posted September 3, 2007 Posted September 3, 2007 Do you by chance have a trailer hitch on it? If so is the stinger in? It could be rattling. I had that happen to me and it sounded just like what you described. Now I know nothing about the 1st Gens but that's my experience with a rattle.
bossman Posted September 3, 2007 Author Posted September 3, 2007 Thanks to both of you. Checked hitch, ok there. I will do the exaust repair this coming weekend. bossman
Guest timshosvt Posted September 4, 2007 Posted September 4, 2007 My rear heat shield on the exhaust had broken slightly free. The bolts were there and I dint notice any unusual movement, but it clearly vibrated and resonated. It wasn't much of a rattle though, it was a zzzzzing with a rattle at the end when the vibrations slowed down. Thanks to both of you. Checked hitch, ok there. I will do the exaust repair this coming weekend. bossman
Guest Popeye Posted September 4, 2007 Posted September 4, 2007 I jacked up my 86 VR & the exhaust collector box had an irritating rattle on take-off only. Thought about fixin' it, but after several hundred miles, it just went quiet again. Since it doesn't hurt anything, I'll fix it [maybe] if it begins to rattle again. Seems like a whole lot of work, though.
bossman Posted September 5, 2007 Author Posted September 5, 2007 Greetings, Popeye I was up in your neck of the woods a couple of weeks ago. Went up to Kansas City K. Next time i head up that way Ill give you a hollar. I plan to head up to Las Cruces next weekend Ill see if it is still making the noise when I get back.
