Dragracer Posted April 9, 2009 Share #1 Posted April 9, 2009 (edited) The final drive seal (Part 22 in this photo http://www.yamaha-motor.com/sport/parts/home.aspx ) is leaking. If anyone has changed this seal, I have a question. Does this seal remove/install from the outside, or do you have to remove part 19 and install it from the inside? Thanks in advance for any advice. Ronnie King EDIT: Sorry, the link will not take you directly to the correct page. I have a 1999 second gen XVZ1300, and the correct page is the one for the driveshaft. Edited April 9, 2009 by Dragracer Link Link to comment Share on other sites More sharing options...
Squeeze Posted April 9, 2009 Share #2 Posted April 9, 2009 http://www.flatoutmotorcycles.com/fiche_section_detail.asp?section=678091&category=Motorcycles&make=Yamaha&year=1999&fveh=18038 You don't HAVe to remove the Cover to replace the Oil-Seal, but it's way easier that way. It's not hard to do, open thes eight Bolts and lift the Cover off with a wider flat headed Screwdriver. Link to comment Share on other sites More sharing options...
