My front left turn signal is out but it does blink when the turn signal is on. I replaced it with a new bulb – no luck, it does the same thing, it only blinks.
I think you're saying the running light is not on the front left but the turn signal still works?
Check for socket corrosion...very common especially on 2nd gens that have the passing lights installed and the turn signals installed upside down making a water trap.
Did you check it with a volt meter?
It is rare in todays market but you can get a new bad bulb
Did you try swapping the bulbs from left to right?
Also did you purchase 2357A bulbs or 1157A bulbs?
You might want to purchase 2357A bulbs for the turn signals and 2357LL for the tail/brake light. I did!!!!
Read THIS thread for technical info.
I'm stopping at the AutoZone on may way home to pick up these bulbs. Might as well do it right the first time.
Thanks for the advise.
